i am looking for a heat press. the main objective is to print soccer name and numbers.
would a 38x38 be big enough or do i need to go bigger?
i was looking at a swing design rather than clamp. i wasnt looking to spend masses. do you think something around the £150-200 mark would suffice?
as an example
https://www.ebay.co.uk/itm/SWING-Heat-P ... Swu0Fe-zDB
quick advise for a heat press
grantsmith82
Re: quick advise for a heat press
It is hard for anyone to 'recommend' anything that cheap. It will work, and it will get you in the business. Some cheap presses last for years and others last for 5 mins.
Only buy cheap if you can afford to buy another at short notice (if it goes wrong) or you are confident that the supplier will offer good after sales support.
For that budget, scour Ebay for used PressMech or Adkins machines - often they go for silly cheap prices - you'd be better served by a pro level machine that is used and maybe a bit old, than something shiny new that is terrible quality.
grantsmith82
Code: Select all
i have had a look online ebay FB etc.. but there isnt anything that i can get to that isnt the other side of the UK.pisquee;144979 wrote:For that budget, scour Ebay for used PressMech or Adkins machines - often they go for silly cheap prices - you'd be better served by a pro level machine that is used and maybe a bit old, than something shiny new that is terrible quality.
what about either of these by Microtec
https://signzworld.co.uk/shop/microtec- ... 8-40x50cm/
https://signzworld.co.uk/shop/microtec- ... 38cm-5in1/
