Does anyone have any tips for avoiding heat tape pressure marks when pressing mousepads? I usually tape my sublimation paper to my mousepads in each of the four corners to keep it in place, but I've noticed that with certain colours after pressing that you can see a faint imprint of the tape that's been pressed onto the mats. A lot of time I can place the paper onto the top of the mousepad without having to take it in place as I'll have a lot of wiggle room as far as the image type is concerned, but I regularly get a lot of images were image placement is critical so they need to be taped into place.
I've tried using tack sprays but they don't seem to work very well for me, especially if images have a lot of very dark areas; the spray seem to leave marks.
Heat press + tape marks on mousepads. How to avoid?
Re: Heat press + tape marks on mousepads. How to avoid?
I dont understand the problem because you tape the paper on the backside of the mousepad and i never had imprints on the rubber. The centering of the paper is very easy because you always have a bit of bleeding areaMartin86;144521 wrote:Does anyone have any tips for avoiding heat tape pressure marks when pressing mousepads? I usually tape my sublimation paper to my mousepads in each of the four corners to keep it in place, but I've noticed that with certain colours after pressing that you can see a faint imprint of the tape that's been pressed onto the mats. A lot of time I can place the paper onto the top of the mousepad without having to take it in place as I'll have a lot of wiggle room as far as the image type is concerned, but I regularly get a lot of images were image placement is critical so they need to be taped into place.
I done get it either. Dont tape the paper to the mouse mat. Tape the mouse mat to the paper.
So the paper is bigger than the mouse mat and tape the mat to the paper.
