Hi all
I am looking to purchase a Nomex heat mat so I can press ornaments and tiles on my clam press. Can anyone tell me where i can purchase one?
Alternatively, has anyone got suggestions for something that will be a substitute for this particular mat?
Many thanks.
Nomex Heat Mat
Littlepop61
Re: Nomex Heat Mat
Not sure about that particular one, but would a SOFT PAD from The Magic Touch or a Teflon pillow do the job just as well?
I have never heard of the Nomex brand, but from I have Googled, it is a conductor of heat that is also soft so you can effectively turn your flatbed in to a basic vacuum press. Both the above items are very good conductors so might work just as well
Littlepop61
Re: Nomex Heat Mat
Hi Socialgiraffe
Thank you for your reply.
I think I will try the Teflon pillow you suggested.
Apparently, they use the Nomex heat mats in America, they are not that well known here.
I wasn't sure about the Teflon pillow for sublimating ceramic ornaments which is why I thought the Nomex heat mat would be better.
Many thanks.
Many thanks.
Re: Nomex Heat Mat
For slates, tiles or glass flat ornament this is what you need: https://ebay.to/3hX0Slx
Or any other as long as is not textured. I use it for years and I only used two as they do not break easy.
Littlepop61
Re: Nomex Heat Mat
Thank you Paul.
I am planning to print small white ceramic ornaments. Do you think the Silicon will be ok to use on these. They are quite thin and fragile.
kind regards.
kind regards.
Re: Nomex Heat Mat
yes, It will be fine. is all about how much you going to squeeze it in your heat pressLittlepop61;144416 wrote:Thank you Paul.
kind regards.
when using matt you need to increase some temperature and time btw...
Littlepop61
