Europa jarin mug press temp
rockersuk
Re: Europa jarin mug press temp
Post by rockersuk »
Just got this mug press used does anyone know how long do you keep mug in press for
Cheers
WorthDoingRight
Post by WorthDoingRight »
Well a good starting point for mugs in my opinion would be 180 deg C (some presses are in deg F so need to check) for 180 sec. If using Ricoh printer then often 170 deg C is favoured for slightly less time. This is assuming that the press is warmed up prior to printing. I use a plain white mug in the press till it hits 180 then turn my machine off, cycle the mugs over and then when it hits 170 deg start the countdown. I work this as being approx 150 secs at 180 degrees. This is however on my generic chinese mug press so your and others mileage may vary
Ragnstoneman
Post by Ragnstoneman »
Thanks , as a newbie here i was able to jump right in and find the answer to my first question from this post :)
