20cm MDF Clock - MockUps?
Re: 20cm MDF Clock - MockUps?
Anyone seen any decent mockup files of the 20cm clocks available ? I have the flat face template but would like a couple more if possible. TIA
Baldy
Post by Baldy »
Mostly flat too, but you can play around with backgrounds etc
https://www.psdmockups.com/tag/clock/
https://we.graphics/item/wall-clock-mockup/
Cheers, I've got those ones already, hoping to find images more like this.....
[ATTACH=CONFIG]6125[/ATTACH]
Flat one is great but could just do with a couple more :-)
vB_ID:6125
vB_ID:6125
Baldy
Post by Baldy »
Doesn't seem to be much out there as far as wall clocks not on wall mockups are concerned.
If I remember correctly, you use sawgrass inks. In which case, you could...
  • Create the design using the new version of Creative Studio
  • Open the 3D Preview and position the clock as desired
  • Use the windoze Snipping Tool to select and screenshot the 3D Preview area and save as a png
-There is a download option within the studio but it covers the image in Sawgrass watermarks
I'm not saying it's ideal...just an option:+)
Yuk, Creative Studio! Lol. I don't usually allow that disk space but if it's an option I'll pop it on temporarily! Cheers :-)
But I'd have to do this for every clock? No Smart Object?
Baldy
Post by Baldy »
I know...esp the new version.
At least the software is online based so no install...and no print manager install either if you're only downloading the snipped mockup images...I would assume.
Where's the 3D option on CS?
Baldy
Post by Baldy »
You'd be able to save the clock as a template and switch out images etc.
I believe there's some clock face design layers you can apply within the software too.
Just found this which may help (Bit about 3D Preview near bottom of article)
https://www.sawgrassink.com/getting-sta ... tivestudio
uhm, different version of CS I'm using online, will have a look around, cheers.
[MENTION=1]Justin[/MENTION] - this would be incredibly easy to model and raytrace to produce views from any angle and lighting to suit. I might have a go later on and post the results.
