Recommend new 10oz mugs please?
MikeJB
Re: Recommend new 10oz mugs please?
Post by MikeJB »
I've come to the end of the road with my current mug supplier. Won't name them, but they are probably one of the largest suppliers in the UK. Quality has been inconsistent for the 18 months I've been using them. Size differences, surface quality differences, chips and bumps, and that's usually in the same box. This evening it took me 7 mugs to get a single acceptable mug due to surface inconsistencies. So, I'd appreciate it if you could give me your recommendations for blank mug suppliers.
Mrteajunkie
Has thanked: 5 times
Been thanked: 3 times
Post by Mrteajunkie »
If you want consistency try mdpsupllies they aren’t the cheapest but if they aren’t right you can email or call and they will put it right.
XP5013 from Xpres. I've been using these for a long time and don't have any issues whatsoever. Some members mention the slight bevel at the bottom but I p[rint full top to bottom in my oven no problem.
BTW....I'd be interested to hear who your current supplier is, PM me if you would prefer.
bubbleimages
Post by bubbleimages »
Another vote for 5013 this end.
MikeJB
Post by MikeJB »
Thanks for the suggestions everyone.
MikeJB
Post by MikeJB »
I've just sent you a PM, Justin.
Justin;141706 wrote:BTW....I'd be interested to hear who your current supplier is, PM me if you would prefer.
rabb
Post by rabb »
I switched from Listawood to Signzworld for the reasons you mention above. So far, so good.
MikeJB
Post by MikeJB »
Which do you use, Rabb - the "double layer coated" ones or the "Orca double coated" ones? Is there a difference as the Orca ones aren't in stock?
rabb;141717 wrote:I switched from Listawood to Signzworld for the reasons you mention above. So far, so good.
rabb
Post by rabb »
I use the double layer coated 10oz large handled mugs.
