help in pressing
Libbymcc
Re: help in pressing
Post by Libbymcc »
hi could you advise me on a press for doing slate and chopping boards at a budget but reliable ,i have a epson ecotank et 14000
Fletcher
Post by Fletcher »
Hi Libbymmc,
You have many choices, alot depends on your budget. A simple pixmax swing press is about £200-£250 or a uk press a little less (both have 2yr warranty). The good quality presses cost mega £££ and imo are not worth it. Just buy a heat temperature gun to check the heat temperature is correct and adjust accordingly.
Hope this helps. Im sure others will comment later.
Libbymcc
Post by Libbymcc »
Need a 40x50 press what would you recommend with a small budget
Users browsing this forum: Bing [Bot] and 3 guests
