Has anyone ever sub printed onto army green 60/40 t-shirts? looking for a quicker way to put one off designs onto these.
I know Xpres sells a army green 65/35 wondered if anyone has tried them?
Many Thanks
Paul, Do you use the 3G jet Pro papers? I brought a sample pack to try out, first thoughts they look good! but reading the instructions the images don't need to be mirrored image, meaning that when I contour cut the image, I am going to need a carrier sheet to apply the design to a tee.paul 44;139445 wrote:If its a simple design, can't you just use vinyl for the printing?
Dark garments aren't ideal for subbing onto, you won't see it.
If it's an image of sorts, can use Jet pro transfer papers etc, probably jet pro opaque 3g might be your best bet?
https://www.yolo.co.uk/3g-jet-opaque--i ... -129-p.asp
