- vB_ID:5673
- Sigma.jpg (17.14 KiB) Viewed 2831 times
Anyone ID the Font in this Logo
Re: Anyone ID the Font in this Logo
Sigma
Thanks Figgy - I did try and ID this with the various sites but no luck.
It certainly does look like [LEFT]Xenois Semi Pro Bold - unfortunately it's not a free font.
Thanks very much
John
[/LEFT]
Thanks very much
John
[/LEFT]
If anyone does have this font, would you be so kind to type the two words in the design and the symbol in the midle and email to me?
I'ts just not worth buying the font for just this one logo!
John
John
you can vectorise it without retyping it. or you need different wording too?
No Paul, exactly as it is.
I did try running it through Vector Magic but the results were pretty grim - it was rather a hurried attempt!!
Have you tried myfonts.com?
Pretty sure you can type in your choice of words/letters
Once done you could try creating a PDF, although you will probably have more luck doing a screen grab and then running a trace from that. The reason I suggest this is because you will get all the letters in black and I think you can zoom in making a nice big file to trace
I hope I have explained that clearly enough
I need to spend some time to vectorise the design
Hi John.
Just had a quick go at this. It's not perfect because the original image isn't great, but here you go ...
[ATTACH]5678[/ATTACH]
Let me know if you need .ai or .svg files instead.
Thanks for that Webtrekker
I managed to get similar using tracing software.
I must learn to use Coreldraw more effectively! Time is always the issue for me.
I do find the tracing function in Wilcom ES3 to be far easier to use than Coreldraw yet Wilcom ES3 is based on Coreldraw!
