Printable Vinyl (BN-20) for Nylon & Polyester?
Stitch Up
Re: Printable Vinyl (BN-20) for Nylon & Polyester?
Post by Stitch Up »
Hi guys
We often print numbers & names for motocross shirts - the really light weight polyester variety. To date we've been using Xpres Subliblock. However, yesterday one of our regulars brought in a new shirt constructed of the following materials:
FABRIC
•Body: 51% polyester / 45% Tencel / 4% spandex
•Sleeve: 85% nylon / 15% elastane
Our customer wants us to print all the sponsors adverts/logo to be heat pressed the body of the shirt as well as the sleeves.
Can anyone recommend suitable printable vinyls for this purpose?
John
You might need two different vinyls for this job, however I would start with Siser C-Print Hi-5. Its a really nice printable film with very strong vibrancy.
The marketing splurge is [FONT=&quot]Performance wear, cotton, polyester, poly/cotton and lycra[/FONT]
Grafityp sell the Sisier range
If this is no good, then Siser's website has a section titled SISER SPORTS which might have a better suggestion.
Ricky@Xpres
Post by Ricky@Xpres »
Hello John
Our Solvent Dark Turbo should do the job for you, Low temp quick press suitable for Cotton/ Polycotton/polyester/Uncoated Nylon:
https://www.xpres.co.uk/p-9366-solvent- ... -roll.aspx
Let me know if you would like a sample.
Ricky
Xpres
Stitch Up;137213 wrote:Hi guys
FABRIC
John
Stitch Up
Post by Stitch Up »
Thanks for the reply,
I'm thinking along the same lines - two different vinyls! Many vinyls do exclude use with nylon, probably because it would melt!
John
Solvent Dark Turbo
Hi Ricky, is this film available in clear?
I don't have a job in mind at the moment, but I do like the look of it for light garments
Ricky@Xpres
Hello Socialgiraffe
The only printable clear we offer is Solvent Light Matt, its good for Cotton/Polycotton and polyester:
https://www.xpres.co.uk/c-442-textile-t ... xpres.aspx
Again if you would like a sample please let me know.
Ricky
Xpres
socialgiraffe;137224 wrote:Hi Ricky, is this film available in clear?
Stitch Up
Post by Stitch Up »
Ricky@Xpres
Thanks for the info.
How does the Solvent Dark Turbo compare to The Subliblock:
1. Resistance to shirt dye coming through - especially on the parts where there's no print? Subliblock has a plastic barrier membrane.
2. The 'feel' of the vinyl compared to Subliblock?
3. Print vibrancy?
Do you have a sample I could print to so I can compare with Subliblock?
Cheers
John
Ricky@Xpres
Hello John
PM me your details and i will send you a sample that you can print on.
For opacity its just as good as Subliblock, it will feel softer than Subliblock as its only 100 microns and its bright white so you will get nice vibrant prints.
Ricky
Xpres
[ATTACH]5625[/ATTACH]
Stitch Up;137234 wrote:Ricky@Xpres
3. Print vibrancy?
Cheers
John
Grafityp C-print PU EXTRA is for NYLON. very good.
