Mug sized sub paper
legacyc
Re: Mug sized sub paper
Post by legacyc »
Evening all,
I recently switched from your typical A4 sub paper to pre cut mug size paper, one of the most sensible moves I've made thus far.
Now my question. Everywhere cut size is 240mm in width, meaning the paper touches the handles, I've narrowed my print size down to around 210mm wide to avoid faded edges, but can find some inconsistencies in the print and edges, something I suspect may be due to the paper being forced off the mug my too much paper against the handle when under pressure in the press.
Does anyone have any recommendations regarding mug cut paper size, do you pre trim like I am now doing, am I missing a trick.
Anyones time is appreciated.
Yes, you will need to guilotine both ends of the mug paper before taping.
legacyc
Post by legacyc »
Okay great to hear my summation is on park!
arthur.daley
Post by arthur.daley »
I gave precut paper a go except mine was 210mm wide. It was just the thing I wanted as Iprint a lot of 1 off transfers and was wasting stacks of A4 paper. My problem was that my printers struggled to pick it up. It would constantly pick up multiple sheets. I made sure the paper was well fanned and separated before putting it in the printer - still mis fed. This was using Magic Touch and Trupix papers in Ricoh 3110 and 7100 printers.
Arthur
cook_58
Post by cook_58 »
legacyc;136794 wrote:Evening all,
Where do you, or anyone else get your precut paper?
thanks.
arthur.daley
The Magic Touch will sell you pre cut paper. That said, just to give it a trial run - assuming you have a half decent rotary paper trimmer, cut half a dozen A4 sheets down. Alternatively, if you have a local print shop with a proper paper guilliotine they can easily cut a box of 100 sheets in one go. Just be sure to get them to cut the A4 into three equal lots - 98mm x 3 which leaves 1mm to trim off the last one. As i said above,I had th devils own time with getting the printers to pick up individual sheets. If I was just printing one mug opening the paper drawer and putting a single sheet in was ok if a bit of a pain. On the whole I found it to be more trouble than its worth and just budget for using a whole sheet on singles or doubles.
I just use a full sheet, printed with crop marks so that I can easily line them up and guillotine them. I prefer to have my wraps virtually handle-to-handle so I print them landscape and get two wraps to a sheet of A4.
Fletcher
Post by Fletcher »
I'm tight i use A4 sheets and you can fit 3 on at 21cm wide on each sheet. Even if i only print one i will then print 2 of my own mugs just to use the paper. so every a4 sheets does 3 prints.
cook_58
Post by cook_58 »
Fletcher;138610 wrote:I'm tight i use A4 sheets and you can fit 3 on at 21cm wide on each sheet. Even if i only print one i will then print 2 of my own mugs just to use the paper. so every a4 sheets does 3 prints.
I usually do this, occasionally in landscape.
I have a template from listawood when I use it in my software it's not correct , it's about half the size is should be. So I need to look into that.
With the pre cut paper, how do you get the peinter/software to pick it up and get the peint on it. Never had to try something like that.
The print shop with a guillotine is an option, not doing that many jugs yet, still learning and making up some here and their for people.
Sent from my SM-N960F using Tapatalk
