Should I 'upgrade' to an oven?
Re: Should I 'upgrade' to an oven?
Post by GoonerGary »
Thanks for the times and all your help. I was using my presses with 4-5 minutes times anyway with really low temperatures to try and overcome fading and heatsink issues. I had much better results with this technique, but an oven will speed me up.
I know which mug wrap seller you were referring to, that was me clearing out his remaining stock a moment ago!
Anyone not convinced yet? Have a quick look at this...
You lot are tempting me to try the oven route again ... the oven we were using is now doing a fantastic job at home in out kitchen, and the 100 green wraps I flogged off on Ebay
mr-gobby
Post by mr-gobby »
Can it cook a tray of chips at the same time :)
Andysam26467
Post by Andysam26467 »
Just took delivery of my Blizzard oven yesterday.
Trying it out today.
Lets hope I can put my mug presses to pasture
mr-gobby
Post by mr-gobby »
mug and chips? Look forward to hearing how it goes
The first batch of mugs I bought, from ebay, came with their own 'chips!' :-)
Andysam26467
First lot of mugs are coming off great. Burnt the chips though :biggrin:
Used 180 degrees and then:
1 mug - 9 minutes
6 mugs - 14 minutes
8 mugs - 15 minutes
Tried doing Polymer mugs in there but the image looked a bit blurry. Maybe due to slight expansion of plastic when hot? gonna do a few more tests with them but ceramics are all perfect. Well chuffed with it
Andysam26467;136651 wrote:First lot of mugs are coming off great. Burnt the chips though :biggrin:
1 mug - 9 minutes
6 mugs - 14 minutes
8 mugs - 15 minutes
Good to hear, one thing to remember, keep the bleed top and bottom to a minimum, I normally have zero bleed at the top and only 1mm at the bottom. Plus, make your paper longer than the green wrap, this prevents the blue ghosting you can get sometimes.
You can add 24 mugs 16-18 minutes to your times :-)
mr-gobby
Post by mr-gobby »
Good to hear progress is being made, shame about the chips though perhaps you used french fries which are usually ready quicker ;)
