Freesub ST-210 Heat up test
Review new equipment, blanks etc.
Mach-One
Re: Freesub ST-210 Heat up test
Post by Mach-One »
Hi all.
Hope this helps, I was rooting in my attic and found my twin probe digital temperature gauge i bought of ebay a couple of years ago.
Anyway probes taped on opposite side of mug to handle, with T1 being the mug base inserted in the right hand side press towards the main power feed for the element.
Room temp spare mug that sits in my press for heat up to idle and cooling down to idle and off etc.
Not too far out each end seeing the base is always going to take longer to heat up.
Enjoy.
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5416
vB_ID:5415
vB_ID:5415
vB_ID:5414
vB_ID:5414
vB_ID:5413
vB_ID:5413
vB_ID:5412
vB_ID:5412
vB_ID:5411
vB_ID:5411
vB_ID:5410
vB_ID:5410
vB_ID:5409
vB_ID:5409
vB_ID:5408
vB_ID:5408
vB_ID:5407
vB_ID:5407
vB_ID:5406
vB_ID:5406
vB_ID:5405
vB_ID:5405
Kit: Microtec Senko 20A 40x50cm, Galaxy GS-202-B Big Pro mug press, Epson WF-7715WDF, Epson 1500W, Cameo 3 cutter, LYU Df-1261_AF 54" cutter.
