Epson 1500w Paper feed woes
Ptmiff
Re: Epson 1500w Paper feed woes
Post by Ptmiff »
Hi all,
I have an problem where I'm trying to print to my Epson (having done so all morning) but now the paper just goes through the machine without stopping to print. Miss feed warning light comes on. I have switched off and back on again (that always works ;) ) but it still just sails through. I'm printing A3 and A4 won't work either.
I've looked at Epson Europe but no solution there has worked either.
Anyone had this happen to them before?
pw66
Post by pw66 »
Happens to me occasionally. It doesn't like paper that is curled on the front edge, so older paper is no good.
Try opening and shuting the cd printer - sometimes that works.
Try putting more paper into the paper feed.
Ptmiff
Post by Ptmiff »
Will give that a try .. many thanks
Post by GoonerGary »
Are your rollers clean? When paper dust collects up on the rollers, it can cause all sorts of slipping problems. Wipe them with some IPA on a cotton stick or similar.
Ptmiff
Post by Ptmiff »
GoonerGary;133102 wrote:Wipe them with some IPA on a cotton stick or similar.
Such a waste of a good beer !!
InkExpress
Post by InkExpress »
GoonerGary;133102 wrote:Are your rollers clean? When paper dust collects up on the rollers, it can cause all sorts of slipping problems. Wipe them with some IPA on a cotton stick or similar.
As Gary said, ensure the rollers are clean as they can get coated from the paper causing them to slip.
Alex
Ptmiff;133103 wrote:Such a waste of a good beer !!
I once tried them both together. Rocket fuel.
Ptmiff
Post by Ptmiff »
Thanks to all .. managed to get the printer to work. It was the paper after all. So hard to see straight when deadlines loom and things go ''wrong''.
