Printer colours changing
PaulOC
Re: Printer colours changing
Post by PaulOC »
I’ve been quite happily printing with my Ricoh 3110DN with sublisplash inks for a while. However at the end of last week the colour has just changed. Light greys are coming out beige, blues are coming out really dark. Everything is just off. I use photoshop and print using the icc supplied. None of those settings have changed. Same paper is being used.
Any ideas whats caused the shift? I know it’s not press related as I can see the change in the print before pressing.
I assume you've done nozzle checks?
PaulOC
Post by PaulOC »
Yes...all clear. The light grey is set using just 29 k so the beige colour is particularly puzzling to me
DyeSubSupplies
Post by DyeSubSupplies »
Hi Paul, if you call 01228 712128 and ask for Neil or Adam they will look into this for you.
PaulOC;132904 wrote:I’ve been quite happily printing with my Ricoh 3110DN with sublisplash inks for a while. However at the end of last week the colour has just changed. Light greys are coming out beige, blues are coming out really dark. Everything is just off. I use photoshop and print using the icc supplied. None of those settings have changed. Same paper is being used.
PaulOC
Post by PaulOC »
Turns out a new laptop was answer [emoji854]
Users browsing this forum: Majestic-12 [Bot] and 2 guests
