Hi All
Anyone recognise this heat press blanket?
I know its is not a Genie 1 from LW
Anyone recognise this blanket?
Re: Anyone recognise this blanket?
- vB_ID:5308
- IMG_2573.jpg (79.9 KiB) Viewed 615 times
DyeSubSupplies
Looks like a best sub one simon, I will double check for you tomorrow
[QUOTE=socialgiraffe;132773]Hi All
I know its is not a Genie 1 from [/QUOTE]
From the photo and the 5 pin connector it does look like a BestSub heat blanket.DyeSubSupplies;132776 wrote:Looks like a best sub one simon, I will double check for you tomorrow
Cheers guys, only problem there then is how I came about having it as I don't remember buying it LOL!!!
Will it fit a DF1?
Will it fit a DF1?
Yes assuming you have the 5 pin connector on the control box. Newer models of the DF1 will be 5 pin connectors as the control box changed around 3 years ago.socialgiraffe;132805 wrote:Cheers guys, only problem there then is how I came about having it as I don't remember buying it LOL!!!
Will it fit a DF1?
