Which heat press
loobyloo
Re: Which heat press
Post by loobyloo »
Hello
I had a cheap 5 in one combo set of heat presses bought for me for Christmas. They have bee fine for learning about sublimation. However friends and friends of friends are now asking me to print small orders of up to 100 mugs and 500 t-shirts. To be honest I don't think the heat and mug press equipment I have at present will cut it. The orders are mainly for charity and none for profit organisations. I don't have a very big budget only £1000. Its for A3 t -shirts and 10 and 11 oz mugs. I have the sublimation printer inks and paper already. I have printed with it and the results have been very good so far.
Any advise would be most welcome
thanks again
Linda
Tubstar
Post by Tubstar »
Hello,
Thats cool that you are getting off the ground with orders coming in like that. We started off with a Single Adkins Studio mug press. They will set you back about £500 new, but you may be able to pick one up second hand. It has always given excellent results. For the flat bed, BMS do a HP3805 which we have had now for about 18 months. The only thing I have ever had to do was a bit of adjustment to the metal flat bed. But it has four bolts to allow you to adjust the height accordingly. We were getting uneven pressure and it was driving me mad until I realised how easy it was to fix. I would recommend both of those from my experience. Although I must confess I do not really use the mug press so much now as I have been starting to use the halogen ovens with more success than previously.
Xpres_Adam
Post by Xpres_Adam »
Hi Linda,
To find out what is going to work for you best it might be worth visiting us as we have many of the Adkins and Sefa presses on display.
If you would like to then please send me over an email:
Adam.roberts@xpres.co.uk
Thanks,
Adam
Adam Roberts | System Specialist
Tel: 01332 85 50 85 | DDI: 01332 85 53 29
Fax: 01332 85 50 80
Web: www.xpres.co.uk
Email: Adam.Roberts@xpres.co.uk
logobear
Post by logobear »
we have used the basic mug press from BMS printer owners for 000's of mugs, less than 150 each, so get 2!
the remaining 700 will buy you a very good second hand Adkins beta maxi heat press, - probably with some change
loobyloo
Post by loobyloo »
Thank you for your help and suggestions. I bought a freesub double mug press and it sailed through the order. I bought a Geo DK20s for the t-shirts - it was more than I wanted to spend but I though well the 500 t-shirt will pay for it. Its a bit on the heavy side but muscles are toning up now and it really is a super press.
Tubstar
Post by Tubstar »
Excellent. Good luck with getting on with it all. ;-)
Alex.
loobyloo
Post by loobyloo »
thanks Alex
