Printing 300gsm Card in-house
Discuss other print methods.
Re: Printing 300gsm Card in-house
Yes I got a good quality corner rounder which seems to work well. I have a Graphtec, I guess you can use a mat with them, never tried tbh. I did think about contour cutting A3 sheets.
Tubstar
Post by Tubstar »
I use pro design 300gsm and 350gsm in our work printers. Its a pretty decent finish that we use on some of our packaging. How many sheets do you need to print Justin?
Alex.
Hi Alex, thanks for your response. If it's A3 I need about 50 sheets printing. I thought I'd get more on a sheet but forgot about reg marks!
Does need to be slightly off white to get close to existing retail stock. I'm getting a half decent result through my laser but it doesn't like the 300gsm ;-)
Tubstar
Post by Tubstar »
I only have white unfortunately sorry. We use SRA3 size which is oversized a3 so you can print and trim it to a3 with edge to edge coverage. You don't need to trim it though. Its 450mm by 320mm.
ATOJAR
Post by ATOJAR »
Hi, sorry to jump in here, im looking for A4 300 GSM inkjet glossy, pre-folder greetings card paper, ive looked all over the net and cant seem to find anything i trust or like the looks of, dont suppose any of you guys could point me in the right detection please?
Thank you.
Just wanted to start this thread up again, we're now looking at a range of card in different sizes for different customers so we think it'll make more sense to look at bringing in-house again.
Looking at the Canon printer options mentioned earlier in the thread. One of our customers designs has small bar-codes, this is my main area of concern as the lines are very close together and it needs to be very crisp. I guess choosing the right card stock will be key.
technick
Post by technick »
Also looking for this. Can anyone help?
Funnily enough, I'm sat here printing 300gsm card now!
Canon printer is in and working a treat. I'm putting the A3 card through my Graphtec cutter on a carrier sheet and I'm getting through them.
I just finished the first 50 cards and found 50 I already had from a previous job! NOOOO! lol.
Annoyingly, we get a small card with the retail pack we use which just gets discarded. The missus asked why i don't print straight onto that.....what a brainwave! So, I put the card in and it prints perfectly! Job done? Nope, it's coated card and the ink won't dry!
So, does anyone know of a supplier for small custom cut card?! Haha. I'll persevere with the cutter :-)
technick
Post by technick »
I'm new to paper prints and had no idea you couldn't print cards using glossy paper with an Inkjet, unless it is a special type of paper. Saying that, i've just found Paper Spectrum who have Inkjet glossy cards��
Users browsing this forum: Semrush [Bot] and 9 guests
