We are currently testing out the Epson ET-2500 with the Sublinova ink and after a couples of profiles this printer and ink set up is working very well.
if it is the regular ink you have installed you will need to remove as much of the ink from the printer as possible then flush it. If you need anymore help or advice give us a call on 01228712128 and ask to speak to Adam.
vynalman;120464 wrote:Yes the machine is plugged in set the heat at 200 degrees centigrade and time 180 I have done medium pressure, and hard pressure the mugs are from X press the paper from incityepress the printer brand new from Epson it is an ET2500
