Hiya. My laptop is in need of an upgrade. Any tips/ suggestions? I run Photoshop, sub printer, normal printer, scanner, silhouette studio for vinyl cutter plus office applications. I'm often running all at once.
Currently have a 6 year old lenovo ideapad. Apparently with VAT increase and pound dropping since then, my budget of £500ish won't get me much of an upgrade so I'm hoping 1 of you lovely lot might know of a deal or be able to suggest something suitable.
Sent from my SM-G930F using Tapatalk
New laptop
theoriginalmadco
- Forgetful8
Re: New laptop
What's the current spec of your machine?
There are some good laptops out there around the £500 mark. Certainly capable enough for running the likes of Photoshop.
You might struggle with USB ports though...I guess a decent hub would sort that.
Take a wander around your local Currys/PC World to get a feel for what's about. Then check online and you may find similar for less.
[CENTER]A bored sailor is a mischievous sailor...
Boy, am I bored![/CENTER]
Re: New laptop
If going for an Intel chip look for an i5 processor ( unless you get lucky and find an i7 for your budget). The extra processing capacity ( over the older i3 ) will be useful when using multiple packages and drivers simultaneously.
- Has thanked: 13 times
- Been thanked: 12 times
Re: New laptop
Whilst away on business a few years ago I bought a very cheap laptop, not sure on spec but we're talking £200 purchase. It was so slow it was useless so I installed a small SSD. The difference was night and day. It doesn't seem to matter what the processor and memory are it does the job so quickly! Corel/Photoshop, no problems.
I use a MacBook Pro for day to day work now and uhm'd and argh'd over a Dell XPS but glad I went Mac for this.
theoriginalmadco
Re: New laptop
Thanks. Hubby has said about solid state drive (ssd-i assume)? But think it will pump price right up. I'm wondering about desktop hidden behind tv and working on lower spec laptop that is essentially the desktop screen so i get grunt of desktop with the portability of laptop. I'm disabled and can't stay in 1 position for long so sitting at a desk all day isn't doable.Justin;129622 wrote:Whilst away on business a few years ago I bought a very cheap laptop, not sure on spec but we're talking £200 purchase. It was so slow it was useless so I installed a small SSD. The difference was night and day. It doesn't seem to matter what the processor and memory are it does the job so quickly! Corel/Photoshop, no problems.
Re: New laptop
The idea is that you keep your existing laptop and replace the slow hard drive with an SSD drive. Your laptop will boot up in seconds. You clone your existing hardrive and copy it onto the new SSD drive..plenty of tutorials on the internet. Your old hard drive and be put into a portable caddy and used as an external/ portable hardrive.
https://www.amazon.co.uk/ELUTENG-Transp ... dpSrc=srch
Asusming this fits your laptop:
https://www.amazon.co.uk/Samsung-inch-S ... drive&th=1
