Passport Cover
Help in finding new products.
Re: Passport Cover
Post by GoonerGary »
I've been asked to source this particular passport cover. I received a sample ages ago, but I've no idea who stocked it. Several sellers on eBay and Amazon use this style to print, so it must be available somewhere. Front side printed only, black on the reverse with a fabric interior with 2-3 card slots. See images attached which I've borrowed from Amazon. Thanks!
vB_ID:5020
vB_ID:5020
s-l1600 (2).jpg (83.21 KiB) Viewed 294 times
vB_ID:5019
vB_ID:5019
s-l1600 (1).jpg (83.38 KiB) Viewed 294 times
Andrew
Re: Passport Cover
Post by Andrew »
Is it the material front or faux leather?
Re: Passport Cover
It has been described as PU leather/ polyester and PVC.
Andrew
Re: Passport Cover
Post by Andrew »
I probably have some if you need them. Not sure who does them with the suppliers though.
Re: Passport Cover
It's ok thanks, I'll be needing an ongoing supply, so looking for either a supplier, or the original manufacturer which would be even better.
Andrew
Re: Passport Cover
Post by Andrew »
No problem. I 've got stock most of the time if your are ever desperate though.
Customprintwales
Re: Passport Cover
Post by Customprintwales »
you can get them from dhgate for $2.53 including shipping, minimum order 100
search for sublimation passport
Re: Passport Cover
No they are all different styles apart from maybe the subliblanks one...waiting for confirmation.
