I always have 2 sheets of chipshop paper over the print, cheap disposable and avoids this ever happening....after having that situation with T-shirts and trupix when I first started.Ian66;107331 wrote:I have just had two t shirts with a ghost image printed from a previous pressing using Jet Stream paper. It seems that the image has bled through onto my Teflon sheet. I never had this problem with the BMS paper so can only assume it's because it is thinner. I have been impressed with the quality but this problem has put me off a bit.
Janners
