Help needed convertiing an AI file to coreldraw x4
John G
Re: Help needed convertiing an AI file to coreldraw x4
Post by John G »
I have a customer that has sent me an AI file which I cannot import into Coreldraw x4.
If anybody is able to do this for me, please send a PM with your email address and i'll email you the file for converting.
It needs to be saved back to Coreldraw x4 which I think is V14 - fonts to curves!
Cheers John
Hi John. Even though the file has a .ai extension, have you tried loading it into CorelDraw as a .pdf?
John G
Post by John G »
I've tried opening it in acrobat reader, saving to pdf and tried opening that - that didn't work. It opened in acrobat OK, so I tried to drag/drop into corel, but it effects the quality.
Earl Smith
Post by Earl Smith »
I have X8, Sometime Ai will open and sometimes not. If nobody else can help the PM me and I will give it a try for you.
If you want, send it to me and I will email it back once converted.
John G;129335 wrote:I've tried opening it in acrobat reader, saving to pdf and tried opening that - that didn't work. It opened in acrobat OK, so I tried to drag/drop into corel, but it effects the quality.
Just try opening in Corel. Ignore the file extension and open as a pdf.
John G
Post by John G »
Thanks for the offer Earl and Simon - I've emailed the file to you Simon.
Cheers John
John G
Post by John G »
I've tried opening it instead of import webrekker, it just doesn't want to play ball
All done and sent back to you John.
Sent as EPS and Corel file.
Not sure what was wrong with it but I had to open it in Illustrator first and save it down to AI 8. Direct import was not working otherwise.
P.S. If you are wondering I have edited my original email so that my email address is now removed :-)
John G
Post by John G »
Socialgiraffe to the rescue - thanks Simon, worked a treat!.
