Laser engraving mugs
Re: Laser engraving mugs
Just had an enquiry (maybe others did as well) regarding being able to laser engrave into a mug (see example they sent below). What an interesting idea. Haven't a clue what equipment would be needed as the cut goes around the curve of the mug. Anyone else seen this before?
vB_ID:5006
vB_ID:5006
laser mug.jpg (12.83 KiB) Viewed 86 times
Andrew
Post by Andrew »
Been around for a while now with the larger printers who cover most methods offering this. Might he Keramikos or even Listawood. Did look into it a wbile back and think thwy might have said they were fired after engraving to avoid them absorbing water. You can get them filled with colour in the engraved part as well.
I'd prefer sandblasting to laser...
[ATTACH=CONFIG]5007[/ATTACH]
vB_ID:5007
vB_ID:5007
