I have a request to supply & print 20 black ties with a block of print to occupy the bottom point in a wedge shape about 13cm up. multi colour print
We will use Premier PR700 poliester ties.
I could use print & cut, or magic Touch WOW, or hand trimmed OBM laser print.
i have no problem sizing & shaping artwork, . but how to apply?
I want/need to avoid the 'pressure' mark you get where the back seam stitches create a fat bit and show through.
I don't want to unsew & re sew after printing.
perhaps I use a teflon cusion under?
Any suggestions / tips ?
Many thanks. Phil
How to print ties ?
Re: How to print ties ?
I know this is slightly different, but when we used to screen print on to ties, we used to slide the tie on to a (tie shaped) jig, this got rid of the ridge effect. When ordering in the ties, we had to make sure you could actually slide the jig inside the tie. A thin bit of metal or mdf would do the trick!
Yes, we have made an mdf board to shove up em!
understand i can use wow at 110c and obm at 120c so should avoid shiney look.
OBM at lower pressure so perhaps best?
logobear;129145 wrote:Yes, we have made an mdf board to shove up em!
Ooh! Hope they're not German ties logo, they don't like it up 'em!
On a more positive note, seeing as most folk never wash a tie, I suppose that leaves a lot of scope for transfer methods.
