Hi guys, I wonder if anyone tried to print on magnetic sheet and contour cut it?
if so, what settings please?
Magnetic sheets in bn-20
Re: Magnetic sheets in bn-20
Don't have a BN-20 Paul but I've cut loads of A4 sheets of printable magnetic sheet in my Silver Bullet.
I use a 60 degree blade, single pass, with a force of between 40 and 100,depending on blade condition. I don't know how that force converts to BN-20 units though, as the Silver Bullet has a considerably higher maximum cutting force.
I use a speed of 400 cm/s, but have cut it at the SB's maximum speed of 800 cm/s before.
Since I use a separate printer it has to be able to handle the thickness of the material. My Canon Pixma ix6850 does this no bother.
