Bms own coasters....
Re: Bms own coasters....
bigj2552;128233 wrote:i have tried every dam thing - higher heat, lower heat...dont tape as hard, tape on harder...shouted, swore, danced around office none of it works ;(
for the ones who are not getting any problems with bms or unisub coasters - UPLOAD A VID OF YOU PRESSING SOME TO LET US ALL SEE WHAT/HOW YOU ARE DOING THEM.
instead of all saying...oooo they working fine for me, show us !
It can only be one of three things ...
Brexit,
The Russians, or
Global Warming!
:tongue:
paulg67
Post by paulg67 »
just out of interest the ones who are having problems with the backing pulling off, how much tape are you using and where are you putting it ?
bigj2552
Post by bigj2552 »
paulg67;128251 wrote:just out of interest the ones who are having problems with the backing pulling off, how much tape are you using and where are you putting it ?
same place we always have - the 4 corners !
paulg67
Post by paulg67 »
i just put it on 2 corners, although that wouldnt make any difference i suppose, but just a tiny bit of the tape touching the coaster, and fortunately up to now i have never had a problem with the backing
bigj2552
Post by bigj2552 »
paulg67;128258 wrote:i just put it on 2 corners, although that wouldnt make any difference i suppose, but just a tiny bit of the tape touching the coaster, and fortunately up to now i have never had a problem with the backing
sorry, but 2 tiny wee bits o tape on each coaster x 6 coasters per a4 sheet - is asking for things to move/fall off between moving them from the bench to the heat press = PITA !
i have a review of the new solejuice coasters coming later tonight..once i clear the back orders we have here ;(
we doing these in bulk my friend..not just 1/2 here n there - a4 sheets x 6 coasters per sheet x 2 sheets on the press at any one time
paulg67
Post by paulg67 »
bigj2552;128260 wrote:sorry, but 2 tiny wee bits o tape on each coaster x 6 coasters per a4 sheet - is asking for things to move/fall off between moving them from the bench to the heat press = PITA !
a4 sheets x 4 coasters per sheet x 2 sheets on the press at any one time, i do these everyday of the week and will be doing upto a 1000 per week minimum in the run up to christmas my friend....just looking for a solution for you, ive always used the xpres coasters with their heat tape and like i said never had a problem with the backing
bigj2552
Post by bigj2552 »
paulg67;128263 wrote:a4 sheets x 4 coasters per sheet x 2 sheets on the press at any one time, i do these everyday of the week and will be doing upto a 1000 per week minimum in the run up to christmas my friend....just looking for a solution for you, ive always used the xpres coasters with their heat tape and like i said never had a problem with the backing
is that all ? :tongue:
paulg67
Post by paulg67 »
bigj2552;128265 wrote:is that all ? :tongue:
maybe not as many as you but at least they’ve got the backing on ��
bigj2552
Post by bigj2552 »
what you think we some sort of p/t bedroom seller like most lol...
paulg67
Post by paulg67 »
bigj2552;128267 wrote:is that all ? :tongue:
no not at all.. you were the one who fetched quantity up, I was just trying to help..I thought that’s what you’d posted on here for
Users browsing this forum: Semrush [Bot] and 3 guests
