Bms own coasters....
bigj2552
Re: Bms own coasters....
Post by bigj2552 »
UK Printed Mugs;127933 wrote:YES!!!! It is happening to all our BMS coasters as well and ODDLY enough we put in a complaint to BMS about the backing issue just last week. We have been talking to Scott who hopefully will look into it. We as well changed over to the BMS coasters about a year ago due to the same thing happening with Unisub.
We "presume" that the BMS coasters are coming from the same manufacturer as the Unisub ones and they use the same backing.
It is again a MAJOR issue as complaints from clients are coming in.
Hot or cold peel makes no difference and we all know useless the Unisub jig is.
Any news from Scott I will post but please also complain as well so they know it is a serious issue.
AH...so it not just us then....thank :eek: for that !
Funny thing is...they started out great....and i mean GREAT ! - hot or cold peel not one bit o coaster came off....
So wth has changed ?
Hold on a sec - I thought the BMS own make coasters were from totally different supplier other than unisub ?
Or they were getting them made themselves ?
I,m sure thats what they were saying at the time they announced they were making there "own" brand of coasters - and they DEF WILL NOT
have the same probs the unisub ones have :rolleyes:
I didnt imagine that now did i ?
And it will not be long before we also will start to get complaints in from punters...as they are getting worse with each bloody order :mad:
Same as unisub - nothing works - apply tape lightly, apply just enough at edges, changed tape etc..
The big question is - we need to buy coasters tomorrow - so which is worse - bms - unisub ?
UTTER RIDICULOUS none of these sublimation trade company's cant get this sorted - do they not have some sort of leverage with the people who make these dam things?
As i,m sure they are buying them in by the tens of 1000's at a time....Jeez ! :rolleyes:
gorgall2
Post by gorgall2 »
I wrap the paper right around the coaster, so that the tape only sticks to the paper and does not touch the coaster.
bigj2552
Post by bigj2552 »
gorgall2;127936 wrote:I wrap the paper right around the coaster, so that the tape only sticks to the paper and does not touch the coaster.
thats ok for doing a few coasters....
but doing around 800-1000 coaster orders, that just not manageable....
At present we use A4 sheet x 2 with 6 coasters on each sheet at a time in the press...to sit n full wrap each one individually, would bot be commercially viable my friend
gorgall2
Post by gorgall2 »
Good point.
Quinsfan
Post by Quinsfan »
Have you put the tape onto the backing and peeled it off without pressing? I could be the glue failing due to the heat from the press?
If you do so many coasters then i would never ever use the tape. Time spend taping would kill all the profitt.
You need a jig.
vB_ID:4921
vB_ID:4921
Tried. Tested. Thrown away. We even went as far as commissioning our own jigs but quite frankly still nothing beats taping down as very tricky to get consistent accurate artwork placement on the paper exactly where is needed for jig. Especially as you can't see the coasters when placing the paper onto the jig and even 1mm out could mean text/logo is not aligned correctly.
John G
Post by John G »
We got a local laser craft company to cut one similar to Paul's example above, but to our spec. Yes it does take time to get the design placement bang on for the likes of logo's that appear close to the edge of the coasters. Certain artworks do need a tweek - but once you do get it right, you'll fly through the orders. We ordered 2 so when one is cooking, the other is having the paper taped to it - times in the press went up by about 10 - 20 seconds, but that could be our press.
bigj2552
Post by bigj2552 »
@ paul & john
yeh fellas thats great....but i cant bloody well find any for sale ;(
@john - thats what i would like to do - have 2 - one cooking, other getting ready ;)
John G
Post by John G »
You would need to get one cut to your spec as coasters from different suppliers differ slightly and may not fit the jig correctly. Try a search for "Laser wood cutters" in scotland and i'm sure there will be someone local to you. Ours are now past there best and warped a bit - next time i'd use a thicker wood and amend the design so it has a back to it, rather than holes straight through - this would make placing the coaster in the jig faster/easier.
Edit: just noticed Paul's example doesn't have holes straight through, that's how I'd get my next jigs made.
