Lines in paper ( Brother J3520 )
keroprint
Re: Lines in paper ( Brother J3520 )
Post by keroprint »
HI,
I have new printer brother J3520 I use it fro sublimation printing .. we getting lines from the roller on the paper
Check this photo
http://prntscr.com/h4zw5w
http://prntscr.com/h4zwek
Please help me fix this problem Image Image
Hi. I see you have made exactly the same post in the t-shirt forum where it was suggested you clean the feed rollers.
You also posted on there that your nozzle print checks are ok.
I definitely think the first picture shows tracking from the feed rollers. What paper and inks are you using?
As for the banding, do some more head cleaning, there's definitely an issue with ink supply. I don't have any experience with Brother machines, are the heads even designed to accept sublimation ink? Do you have an ICC profile?
Post by GoonerGary »
Clean your rollers, clean your 'pizza wheel' feeder and make sure that you are using the correct media settings for your paper.
