hi Steve, I'm reluctant to change because I haven't a clue about ICC profiles. Is this simple to change? (And when I say simple, I mean VERY simple)! Scares the hell out of me tbh!DyeSubSupplies;125892 wrote:Hi Paul, yes the swap out kit comes with instructions of how to swap out your old ink onto the sublisplash, no need to use flush out carts now. The swap out kit comes with an extra free set of carts to compensate for any ink wasted due to the swap out.
if you would like to see a printed sample before buying feel free to get in touch and I will get Adam to sort you one out for you.
steve
Ricoh printer ink
Glitterbomb
Re: Ricoh printer ink
DyeSubSupplies
Yes very simple and straight forward full instructions are given with the swap out kit. However Adam in our Technical Support Dept will be more than happy to go over it with you and if you want he can log in to your computer and set up with all the correct settings including installing the ICC profiles. The other option would be to call in with the printer and Adam could of done it here, however Bristol to carlisle isn't just down the road!!
Just a quick photo of guitar strap printed with sublisplash for “new buyers”
