Thanks.
So would you consider ink as a supply and not inventory? As you are not making profit from the ink? In that case, would it tax deductable?
Esrimating ink cost for quote
Re: Esrimating ink cost for quote
Thanks.
So would you consider ink as a supply and not inventory? As you wouldnt be making profit from the ink. In that case, would the ink be tax deducatable?
Yep, as it is a consumerable it is tax deductable! In fact most of the items bought to make the item, ikn, paper etc is tax deductable
Wondered what machine your using when costing this pisquee, do you use a wide format printer for sublimation regularly as interested in the cost comparisons and savings over desktop.
pisquee;123880 wrote:It depends on the size of the print - if you're printing on a 44" paper roll by the metre, those pennies soon add up!
For costing purposes, I currently work on £2 per square metre to cover paper and ink, which is over the actual amounts, but helps go towards the cost of running the printer, wastage etc
