Coreldraw
Bwfcuk
Re: Coreldraw
Post by Bwfcuk »
Looking for a copy of CorelDraw, not fussed re version. I just want
to re acquaint my self with Corel. New computer no CD drive so must
be on memory stick if poss..
THANKS IN ADVANCE..
mrs maggot
Re: Coreldraw
Post by mrs maggot »
it is available as a download, you could always buy the student version.
a portable cd drive is about £19 to buy i had to get one for my new laptop
Stitch Up
Re: Coreldraw
Post by Stitch Up »
I don't think the student version allows you to interface with Cutting Master?
Not sure but just a thought.
John
Quinsfan
Re: Coreldraw
Post by Quinsfan »
I have just downloaded the subscription version of Corel and that won't work with cutting master but the trial version of x7 does
Bwfcuk
Re: Coreldraw
Post by Bwfcuk »
Thanks guys, I may go down the student version. not doing any cutting just subli designs
to send to a friend who has a wide format subli set up. fancy doing large flags and banners..
just a thought are you allowed to use the student version for commercial use ??
mrs maggot
Re: Coreldraw
no you are not BWFCUK its a student version, so you need to be a student to use it, are you at the university of life?
Re: Coreldraw
I've just bitten the bullet and upgraded to X8. Corel wanted £600 (They will knock 50% off this though) but I bought from the US for around £150, full commercial boxed version. I've always worked well with X4 but needed the cutting master to work directly.
Stitch Up
Re: Coreldraw
Post by Stitch Up »
Coreldraw X6 is not compatible with Windows 10 = very annoying!!
Dalbag123
Re: Coreldraw
Post by Dalbag123 »
Hi Justin
can this just be brought from any U.S. Site? And is it like compatible etc? Just asking because that's an amazing saving and i really want to get onto Corel draw.
Re: Coreldraw
I'll send you over the eBay auction I bought it on. I think it was £153, plus taxes etc. it still came in under £200. There's a slight issue installing X8 that I am now aware of! It tells you to remove all previous versions but even once you have it still fails. It appears you have to remove Microsoft Visual C++ 2015, install X8 and then reinstall Visual....just in case anyone has this issue!
