black print on paper turns out Yellow/greenish after heat press!
Bispham
Re: black print on paper turns out Yellow/greenish after heat press!
Post by Bispham »
Wondering if you had any advice....Bought a subli-kit from City Ink Express
I've printed to their sub-paper....looks fine on paper.
vB_ID:4694
vB_ID:4694
After heat press it transfer (via HPC480 heat press from Signzworld)
190C for 60Seconds
onto gildan polyester T
the result for black is yellow/greenish.
Any ideas why this is happening?
#disheartened :frown:
MY GEAR
city ink express
EPSON Subli Kit
[/FONT]
my HEAT PRESS
Not being funny here but your 'black' transfer prints look green to me.
Is your ICC profile set up correctly? What software are you printing from?
I've heard of green blacks being a problem before with Epsons.
Bispham
Post by Bispham »
Hi, I used these settings in Illustrator...
vB_ID:4695
vB_ID:4695
cityexpress settings 2017-07-15 at 12.41.20.jpg (10.43 KiB) Viewed 427 times
I installed the ICC from the City Ink Express disk I got with the bundle
The graphic comes black on the paper but when heat pressed is pale green/yellow.
The result of the colour wheel(which I downloaded from google images) test transfer failure is very disappointing too.
Looking like the cyan head is blocked. There's also some terrible banding on that colour wheel.
Have you done a nozzle check?
Bispham
Post by Bispham »
Does seem like the Cyan is not turning out after the heat pressing despite it looking OK on the sub-paper.
I've run a nozzle check and there was a slight break in the magenta only. I've since cleaned the heads.
Have you tried sublimating a different product: mug, aluminium sheet, coaster, etc?
Also, is there any possibility the cyan ink may not not be sublimation ink?
Bispham
Post by Bispham »
I've only got T-shirts. There was regular ink in the printer before. Maybe I need to purge that out?... I'll print some bands of CMY&K. ......IT SEEMS TO HAVE WORKED! :redface:
The black does have a dark green tinge though upon closer inspection.
Another thing...
The print has gone through to other side of garment. Any suggestions for what material to put in-between to prevent this?
Just some cardboard or a sheet of greaseproof paper popped inside the t-shirt should stop the print sublimating through to the back.
Angloman
Post by Angloman »
Try using proper sublimation ink
Directdesignsupplied.co.uk
green19
Post by green19 »
Sorry to jump on you thread but I have a similiar setup can anyone recommend the best sublimation paper to use ... thanks in advance
