Pencil case dark area following seam
Customprintwales
Re: Pencil case dark area following seam
Post by Customprintwales »
I'm sure someone has come across this before and could give me some advice.
I've been having problems printing the pencil cases. When I press the case flap there is a slightly darker area of print that follows the inside of a slight seam.
Is this because I am pressing too hard or too long?
thanks
Kevin
Can you post a quick pic?
Customprintwales
vB_ID:4685
vB_ID:4685
Hope this helps
Kevin
