Higher Resolution with Virtuoso 1200x 1200dpi vs 600x 600dpi with Ricoh?
Interesting, my (far more expensive) VJ628 won't print at 1200 x 1200, well, it will but puts too much ink down on the paper to allow a decent profile.
Ricoh 3110 , replacement?
Ricky@Xpres
Re: Ricoh 3110 , replacement?
Are you using the VPM (virtuoso print manager) with your VJ628 ?Justin;124271 wrote:Higher Resolution with Virtuoso 1200x 1200dpi vs 600x 600dpi with Ricoh?
Sent from my SM-G935F using Tapatalk
Ricky@Xpres
Do you have a profile for your paper in Wasatch ? And do you have florescent inks in your VJ628 ? If not it might be worth installing the VPM as it has profiles for a number of papers including True pix . This might get you better results at a higher dpi ?Justin;124275 wrote:No, all done through the Wasatch RIP.
Many profiles. Sawgrass also made one at 1200x1200 but it's no use as it puts too much ink down. Need the RIP I'm afraid.
No worries, I don't want to change the direction of the thread, cheers
Exactly what my sources said as well. The SG3110 may stop production but the Sawgrass badged printer will continue.The SG400/800 are not being discontinued
Novachrome.co.uk sell the Sawgrass 2 year warranted sg400 for £350 and the sg800 £899 which is a considerable saving on retails of £429 & £1324 (all plus vat). They are supportive, include a remote login service if needed and attend most of the shows including printwear and promotion, next at the print show in Telford this October. I've spoken with them a few times and found them helpful and informative. If your looking for a 3110 replacement with Sawgrass ink this maybe the cheapest available.but for how long I don't know.
