Printing direct onto DVD's
Re: Printing direct onto DVD's
I have a customer looking to get 300 DVD's printed and I want to do in-house.
I've done them before on my Epson 1500w a long time ago and results always seemed excellent. I'd like to buy a dedicated printer for this and wondered if anyone currently printed dvd's?
Initially I was thinking Epson again but looking at the Canons they seem excellent value. I had a Canon Pixma and photo quality was excellent, Canon do seem quicker as well.
Looking at the Canon i7250 Printer which for £50 all be it an older model seems superb value. Just wanted to check there wasn't a better model at this price? I don't want the scanner/copier functions.
Customer supplying inkjet printable DVD's, now I just need to work out what to charge!
I have one of these and can not fault it for the price. Great little workhorse.Looking at the Canon i7250 Printer which for £50 all be it an older model seems superb value. Just wanted to check there wasn't a better model at this price? I don't want the scanner/copier functions.
However, if you are intending to get into DVD/CD printing then why not look at a "proper" dedicated machine, something along the lines of a Primera. These will publish as well as print meaning you could offer a total one stop solution.
Thanks Simon, does look ideal. I doubt I'll do many more so this will be fine
Stinkyink do decent compatible inks.
Something like the i7250 would be my pick mate, inks about £0.40 a cart.. will do the job no problem, (I use a Canon mg5300) not sure why you would want to spend £100's on a disk printer unless you had it working everyday :rolleyes: so many people have this option to print disks at home there's no ££ in it, I used to print 100's a week and did it for years, to burn and print a disk you're looking at £1-1.50 each that's to supply the disks and sleeves/cases ..
Great, thanks for the endorsements.
I was hoping to charge about £1 per DVD just for the printing. Not great shakes but this is a new customer that may well want other items.
cyprian.costelloe
The primera printer is too expensive to run, if you want a dedicated machine go for the Epson disc producer, I can give you a name for a ciss system for the machine, ink costs should be around 2c per disc. Discs should cost you about 12c. After that packaging ranges from 2c for a plastic sleeve, 16c for a dvd cases up to 24c for a jewel case and tray.
But to be honest I would buy a couple of canon machines and use a "watershield" disc they are a bit more expensive but your client will love the finish.
Been selling cd and DVD packaging and equipment since the early nineties so if you need info or names just ask.
Sent from my HTC One_M8 using Tapatalk
Thanks for responses, much appreciated. Not something I will be getting into, this will probably be a one off.
I'm mindful of the time it would take to print 1 dvd at a time so don't really want to do this for less than £1 per disc. No response from customer as yet so not sure if they feel this is too expensive, we'll see
Customprintwales
I do disc printing and use a Canon iP7200 because I don't do that many - I use it to send out promotional DVD's and a good professional look on the disc is essential.
The My Image Garden software that comes with canon has a good selection of templates for both the DVD and DVD case, so you just need to add your images or mages and text.
You can also design up your own complete image to use on the disc.
I guess the image and finish you get will be dependant on the quality of the printable disc you use by I'm very happy. It takes about 30 seconds or so to print a disc at high quality print.
Bought and setup the 7250, trying to print from Image Garden but it just hangs! Reinstalled everything, latest versions etc. but no go
I'm only running wi-fi, will try direct usb connection to see if that helps. Emailed Canon Support for advice, tried a few other software trials but they only print a label not direct to dvd.
Customprintwales
Yeah, I've occasionally had problems with Image Garden.
I can not remember where I downloaded it from now but I'm sure it was from cannon itself - try Canon Easy-PhotoPrint EX.
I think it is pre-Image garden but I use it for a backup in case image garden plays up. But to be honest with you because it is so less complicated I find it easier to use and getting the image centred and the right size for printing onto disc is also easier.
