Full height printing
PhilTheMug
Re: Full height printing
Post by PhilTheMug »
Is it possible to print (using mug press) the whole height of the mug as shown here?
http://cgi.ebay.co.uk/Tiger-Woods-Golf- ... 3a474a971a
Phil
Yes, with a decent mug press full wrap is achievable. The usual issue that causes a problem is that the mug edges aren't straight. The mug tapers a little at the top edge. A good press allows for this.
purpledragon
Post by purpledragon »
quite a lot of mine are full height and i rarely have problems as justin says you need a decent mug press
Brett
PhilTheMug
I've PM Martin asking for a starter pack 'deal'.
NASH
Post by NASH »
just move the mug up the press and press the bottom part of the base
logobear
Post by logobear »
The main issue is incomplete Transfere around the bottom as the ceramic base draws out heat.
If you put an inch of boiling water into the mug to pre heat it for a minute before emptying drying and pressing it is usually good.
snjokaggl
Post by snjokaggl »
I've found with my heat press that this is unnecissary because the heat press starts at 110c and climbs up to 180c before starting the timer so the mug get's pre heated and the bottom comes out great.
You should contact Martin as he has this model that I'm using.
We've the standard models of these coming back into stock again tomorrow (Tuesday) - the DF1.
fredster
Post by fredster »
i have the new model from martin too and its the dogs b ......s :D wish i :D 'd have bought it sooner ...
smartarts
Post by smartarts »
The DF1 mug press from Martin is great, most of my mugs I do a full wrap on with no problems. I have images on my gallery that you can see.
