Ultra sticky self adhesive vinyl required for outdoor use?
Re: Ultra sticky self adhesive vinyl required for outdoor use?
Can You recommend any brands/types of vinyl that is ultra sticky which can be used outdoors for decals/badges.
No such thing unless you are thinking of vinyl for high energy plastics.
3M Vinyl isn't that different to standard pic vinyl? I was informed it is more suitable for outdoor car vinyl badges/decals ?
What are the benefits of purchasing a branded vinyl such as 3M, Metamark etc?
What do you mean by outdoors decals/badges? Most decals/badges end up outdoors at some time or other so a bit more info would help in helping you. Are you looking for decals going on bikes, cars, walls, windows etc etc because there is a variety of vinyls on the market for each of these applications. Are you looking at self coloured decals/badges or printed ones?
I would like to create some badges for cars/windows, the vinyl adhesive I have doesn't appear to have a very sticky backing when applying.
I have also applied resin to some of the vinyl stickers with the same results, I have attached a image of the media type and the type of badges I would like to create.
- vB_ID:4513
- domed-labels-round.jpg (92.05 KiB) Viewed 316 times
- vB_ID:4512
- 750x750_1470153883Label17.jpg (89.54 KiB) Viewed 316 times
- vB_ID:4511
- Screen Shot 2017-02-17 at 13.03.03.jpg (19.52 KiB) Viewed 316 times
What vinyl are you using at the moment because unless there is something wrong with it or it is not intended for the purpose you are putting it to I can't see what difference it makes to the adhesive qualities.
I purchased the following media https://www.grafityp.co.uk/digital-medi ... -blockout/
DG 100 GLOSS BLACKOUT DIGITAL
Ahh that's the easy removable stuff, might as well have used static window film.
They don't advertise it as that this is the description they have on their site DG Cal 100µ white blockout monomeric digital print film. 50 metre log. Permanent acrylic adhesive. Suitable for interior and exterior use.
What would you reccommend for permanent outdoor use? long lasting
Thank You
Thank You
everyone has their own preference..... at the moment I like Poli=Print 820 Digital.
