Black mugs.
Mugshots
Re: Black mugs.
Post by Mugshots »
Ok. Ours are more than 2cm. Id be happy with 2cm
ArferMo
Re: Black mugs.
Post by ArferMo »
Have a chat with Sim at Listawood.
Andrew
Re: Black mugs.
Post by Andrew »
Listawood should be fine and also someone like subli who use Orca. The Orca version has a slightly larger panel but both give a full wrap.
Re: Black mugs.
If you only require in blocks of 20 why not use a "proper" black mug and the white laser transfer system?
At least you get a real black mug then.
ArferMo
Re: Black mugs.
Post by ArferMo »
You no read post #1 that's what the OP originally asked for.
Re: Black mugs.
I did and know and to be fair, that is not what the OP originally asked for, my comment is more about why white panel mug is in question for such a small quantity.
