Sublimation Ink
laberge86
Re: Sublimation Ink
Post by laberge86 »
I have a SG3110dn printer and have started to run a bit low on ink. Can i use any sublimation ink or does it have to be the specific one for that printer?
Quinsfan
Re: Sublimation Ink
Post by Quinsfan »
What ink is in the machine now. If you have done things the right way around I would assume it is Sawgrass
malkram
Re: Sublimation Ink
Post by malkram »
Ricoh needs gel-based ink, so you must use specific ink. Either Sawgrass Sublijet or any other sub ink specially made for Ricoh's
laberge86
Re: Sublimation Ink
Post by laberge86 »
I've seen a few on ebay and amazon that are cheaper, but weren't 100% sure if it had to be sublijet or a non-named brand one
malkram
Re: Sublimation Ink
Post by malkram »
You can use another brand but only if they say it's sublimation ink compatible with Ricoh's (because they need gel-based ink, while other printers use water-based ink). That said, I'm only talking about compatibility, quality is another thing, if you buy bad quality ink with no ICC profile you are wasting your money.
