ICC Profiles
Bob700
Re: ICC Profiles
Post by Bob700 »
Hi
Apart from Paul is there any other member that could do an ICC profile.
Thanks Bob
ArferMo
Re: ICC Profiles
Post by ArferMo »
There are several of us on here with the kit to make them.
Bob700
Re: ICC Profiles
Post by Bob700 »
Sent you a PM
willd
Re: ICC Profiles
Post by willd »
ArferMo;119003 wrote:There are several of us on here with the kit to make them.
I'm a little intrigued by the process for producing an icc for a dyesub printer - I know that with a colormunki one can produce profiles for various bits of kit, depending upon which particular colormunki that one has. That's straightforward enough for a normal printer, but somewhat more complex for a dyesub printer?
The colormunki needs two prints to come up with a profile, to be meaningful they'd have to be pressed onto the relevant substrate, and they're A4 sized as I recall - bit difficult to do that on a mug!
I've no need to produce profiles for our dyesub printer as it's producing very good images, but have to say that I'm curious...
insight
Re: ICC Profiles
Post by insight »
I used A Datacolor SyderPrint using my template in Photoshop positioned the colour chart on to 2 mugs then scan when done.
I use a Epson 1500w with inktec, out of box (no icc used) colours good but too light.
Suppliers icc too dark and wrong.
Inktec profile very good slight difference but near perfect.
Calibrated profile spot on.
insight
Re: ICC Profiles
Post by insight »
malkram
Re: ICC Profiles
Post by malkram »
mags1892 also does profiles if I'm not wrong
JMugs
Has thanked: 10 times
Been thanked: 10 times
Re: ICC Profiles
Post by JMugs »
With a Munki I use the MDF panels for the profile. Mugs can vary in shade of white so works well. All other things have their own profile.
Re: ICC Profiles
Use a Spyder here - use cheap (not chromaluxe) white aluminium to cover everything that is hard/glossy, and then do a specific profile for each fabric we print. Our lampshade fabric being the most (pure/bright) white, so we use this for fabric products we don't haven't got profiles made for yet.
mags1892
Re: ICC Profiles
Post by mags1892 »
To be accurate you need a good meauring device like a i1pro syder doesnt measure with enough bandwidtg its desifned for monirors. I1 measures every 10 nanometres.
Sent from my SM-G930F using Tapatalk
