is that cutter worth any thing?
Re: is that cutter worth any thing?
"it comes with windows driver and you are able to cut direct from coreldraw,illustrator"
you will get 1 x laserpoint seiki sk720t pro vinyl cutting plotter with stand
plugin driver for coreldraw,illustrator,autocad,inkscape
Is that an optical eye I see on one of the photo's ? I'll bet most suppliers charge this much for the stand alone! lol.
Even though mine is supposed to cut from coreldraw I never got away with it. I always design in corel, export, then import into artcut - its long winded but at the end of the day coreldraw is a design programe, not a cutting programe.
is there any free cuting program? I designe most of my designs in crd corel.
Most come with art cut - a simple export as curves and import into artcut does the trick. If you want to use corel you have to put a hairline outline of around 0.01 (I think) then cut. Problem i had was anything that already had an outline confused corel and refused to cut so I used artcut instead. No hardship.
[url="http://download.rolanddg.jp/en/downnew.html]http://download.rolanddg.jp/en/downnew.html[/url]
I think the Roland CutStudio is free and works as a plug-in. I used to cut direct from CDraw as John has mentioned above.
hats what I need! some sort of plug in like with craft robo. click the plug in and off you go
ok. bought it. hope everything will be fine. finger crosed. will let you know when it arrive.Justin wrote:Buy it and review it for us....go on Paul...go on.....
will it work with other cutters? or is ir roland only?Justin wrote:http://download.rolanddg.jp/en/downnew.html
