I have had my press for just over a year, had a few replacement parts etc, platen, handle and controller but touch wood, all is good so far.
I had an issue with the handle, now it wont snap shut onto the base, I had a replacement handle sent out which is a little shorter than the one that came with the machine and has been sat in my cupboard ever since.
This machine came with the base plate which is held on with 2 bolts onto the chassis of the machine, as the new handle is to short (not enough pressure when pressing) I have just put 4 washers on each bolt onto the base plate where it connects with the chasiss of the machine to raise the base plate height so I can now get optimum pressure on anything i print.
Just a little tip if anybody has had or is having a problem like this.
If anybody has any other tips, please post them!
tips if you have a chinese press
Re: tips if you have a chinese press
my tip having a Chinese press is get rid off it asap you can afford to by a well known branded press even a used one ( Going for less than 500 on ebay used ones but in good condition ) .You will see the deference .....
yup, one of mine that I have on the list, im going for a 15 x 15 galaxy £500.00 new from subliblanks..when I get the cash that is
Well I've just gave my press another good few years extra life (well my brother did as he's an engineer)
