Hi Guys
When the mugs are coated with polyester is it just the outside or is it also inside and on the handle. I have been asked if I can print on the bottom and on the inside of the mugs
paul
Mug coating coverage.
Re: Mug coating coverage.
Its just the outside so a definite no to the inside. Depending on how they are sprayed (right way up or upside down) will depend on if you can print on the base, but even if they are coated on the bottom it will not be a great coating.
Thank yousocialgiraffe;117000 wrote:Its just the outside so a definite no to the inside. Depending on how they are sprayed (right way up or upside down) will depend on if you can print on the base, but even if they are coated on the bottom it will not be a great coating.
- UK Printed Mugs
There are lots of threads on this topic by the way but supplier Listawood can supply mugs with pad printed logo on bottom.
