Cricut or ebay cutter
jimmy oldskool
Re: Cricut or ebay cutter
Post by jimmy oldskool »
ive been planning to purchase this
the cricut explorer air but then came across this
http://www.ebay.co.uk/itm/VINYL-CUTTING ... E-FORMAT-/
it will be for abit of everything original plan was to be mainly used for making stencils to etch glass but also now thinking about wall art and also the drawing capabilities.
which do you guys think i should get ??
thankyou
get the descent one if you planing to make descent money.
All of them will work but buying roland or graphtec you can save yourself sooo much hassle. Cheaper cutters tend to have a trouble with printing BIG artwork duo to buffer.
But of corse it all depends of your budget.
jimmy oldskool
thankyou for the reply mate. my budget is around 200 mark i can get a cricut explorer air bundle for 220 the other larger cutter is 180 my worries are that the ebay cutter will struggle with smaller detail cutting for the glass etching?
scotty44
Post by scotty44 »
As Paul has said, go for something tried and tested it will save you hours/days of messing :wink: most of us have been there done that!
I'm a big Roland fan, still use my Camm1 even though I have a BN-20 sitting here, saying that if you're only doing small stuff you wont go wrong with a Cameo, I use mine ever day for small stuff
Up the funds a little and go for something like this if you need a 24" cutter .....
eBay item number:
182326010838
I have an 18" Silver Bullet from Thyme Graphics https://www.thymegraphics.co.uk/products.asp?cat=102
You can also get a 24" model. They have 4 moveable pinch-wheels and more than double the cutting force of the ebay machine in the OP. They have a 'laser' (red dot) alignment system for print & cut which is extremely reliable and deadly accurate.
I also have a Silhouette Cameo which is sitting gathering dust. It's a toy compared to the Silver Bullet.
I'll also add that the aftersales service and support is second to none and the best I've known anywhere, thanks to the owner Dawn.
I use my SB every day (over a year now) cutting items for my daughter's ebay shop. It cuts through 650gsm magnetic sheet like butter.
You can often pick up a used machine from their support forum at http://www.thymemachines.com/
arthur.daley
Post by arthur.daley »
the Silver Bullet is undoubtedly a superior cutter when compared to the Cameo but at £655 for the 13 inch SB it is well over double the cost of a Cameo
Anyone know if the Cougars now unobtainable or just sold out awaiting a new shipment from the US?
Arthur
scotty44
Post by scotty44 »
arthur.daley;116475 wrote:the Silver Bullet is undoubtedly a superior cutter when compared to the Cameo but at £655 for the 13 inch SB it is well over double the cost of a Cameo
Arthur
This is true Arthur but the OP is looking at around £200 so the Cameo would be my option for making stencils, a version 1 could be had for less than £100 ...I would still go for a Roland :wink:
jimmy oldskool
thankyou for the replies.
i think im going to go with the cricut as majority of the work ill do will be small and detailed work. i will then upgrade to a larger cutter when i have money to afford a decent one.
jimmy oldskool;116481 wrote:thankyou for the replies.
Wise decision. Always buy gear that does more than you want it to as things change and you're left wishing you'd gone for the better model. You may well end up doing things you'd never even thought about when considering a cheaper model. I did.
