Right guys I am using a Ricoh SG3110DN sublimation printer, with Trupix A4 sublimation Paper, I have just watched another vid of printing to a ployester shirt etc and the print on the shirt came out
perfect, now I tried with near enough the same picture etc , but what all these vids dont tell you or show you is the printer settings, only the page being printed and then heat pressed,
as I say I went to print with the same ish picture and the print was bland faded colour and not as good as on the Vid, so has anyone got any tips on how to create a perfect ish image that looks as it should on a
ployester shirt,
thanks in advance guys
you tube polyester vid
Re: you tube polyester vid
What inkset are you using? If it's Sawgrass you need to have the Powerdriver or a profile installed, if it's not Sawgrass the latter still applies.
