Poor quality images
Dave271069
Re: Poor quality images
Post by Dave271069 »
Personally i would try pressing something before you carry on, You have said your images are not correct, well as soon as you press an item you may well be surprised and delete the whole thread.
De8n
Post by De8n »
Hi dave. Thanks for you're responce. The image I've printed is very bright and vivid on my computer but once printed looks dark and the colours are not clear and bright. Would pressing the image make the colours brighten up ?? That would be a nice simple fix haha. I did try printing using various paper type settings and quality setting a bit nothing really changed the outcome
froggy
Has thanked: 1 time
Been thanked: 2 times
Post by froggy »
Press what you have printed and then make a comparison. The printed image will not look as vibrant as the image on PS, also your monitor setting will most probably be off, but dont worry about that for the time being.
De8n
Post by De8n »
Hi froggy. I press an image last night and was actually surprised with the result. Although it didn't look anything like the image on my screen (my Mac is connected to a 50inc HD TVs not a monitor) the image did look different to the print before it was pressed. Obviously image on left of picture is pressed phone case and right is the printed image. Should I be expecting bright images than this is or is this the quality I should expect. ?? Thanks all again who have responded and given me advice ��
vB_ID:4226
vB_ID:4226
froggy
Has thanked: 1 time
Post by froggy »
The colours dont look too bad, however I dont know what the original image looked like. Try setting your white, grey and dark point in photoshop using levels,it will help to correct the colour temperatures within the image.
bmhdg1976
Post by bmhdg1976 »
The printed image will always look "wrong". We did a image the other day that was black through to green blend and when printed (Sawgrass printer and inks) looked very blue. But once pressed they were perfect! Always press onto something as the prints never look the same as you would think.
De8n
Post by De8n »
Yes thanks bmhdg1976. I have now pressed a case and posted a pic of the results above and was very surprised how different it look and was quite happy with the result ��
