DAE HA UK / Garment films UK any good?
Re: DAE HA UK / Garment films UK any good?
Has anyone tried this brand of vinyl supplied by Garment Films Uk?
Prices look good and good range of materials and colours.
Thought I would check before I had a go with them
Mimaki CG60-st cutter , Ricoh 3110 sub printer , OKi laser , Epson inkjet , 2x heat press , mug press , cap press, Flexisign pro and coreldraw X6..............and learning ...........
and now a Roland SP-300v Versacamm !!!!!!
Not tried them so be interested to hear anyone's views especially on the printables.
Andysam26467
I use them all the time. They are great to work with and weed easily.
The only problems I've had with them is the vinyl separating from the backing forming air bubbles if not stored correctly (mainly off cuts)
The glitter range is fantastic.
Andy
Andy
Rob Adcock
i have used them for a couple of years now in fact dont use anything els, the glitters are fantastic
Glitter is brilliant looking, we use it on 'T's and bags but initially it was a 'barsteward' to cut(Graphtec 5000-60).....eventually found pressure of 25 and 3 cuts does the trick.
Thanks for the replies, just ordered some to give it a go
mags1892
its good stuff korean manufacturer one of my client only used this for some high end stuff that was actually on show at the olympics , swears by it
we've had good experiences with Dae Ha - were having proiblems weeding MDP's Hotmark Glitter so tried Dae Ha's and havent looked back - their Stretch Metallic is great too - try and get to Print&Promotion Live at the NEC last weekend in Jan where they will be exhibiting and pick up some samples - can defo recommend - good prices too
I'm fairly sure that DAE HA supply some of the Ralawise vinyl - the glitter particularly seems exactly the same.
milspectees
They say the don't supply to Ralawise. Most of the Ralawise vinyl is supplied by Magic Touch. The Dae Ha stuff, especially the reflective and effects stuff is way way betterleedjc;130003 wrote:I'm fairly sure that DAE HA supply some of the Ralawise vinyl - the glitter particularly seems exactly the same.
