Hi
Sometimes my Cameo does not cut the complete image but leaves bits out or won't cut the complete letter, it's the first Cameo produced, anyone have any ideas of how to cure this
Cameo missing bits out
Re: Cameo missing bits out
Earl Smith
Hi Bob. Maybe you have already solved this problem as this post is two days old.
I dont have the Cameo but I have had a similar problem with my GX24. I do all my design work in Corel and the solution is to group everything in the design together within Corel and then export it to the cutter, then the cutter can see what has to be cut.
