frosted mugs
Re: frosted mugs
hi any one try one of them before?
Love_cut is seling them on ebay and I wonder if print on them look any good. I love to see picture of one of them printed.
Re: frosted mugs
They come up good, but you must preheat them at 60 - 80 degrees for up to 5 minutes and then press. Otherwise you can crack the base of the mug away from the thinner sides.
Re: frosted mugs
:o :shock: so is not very practical then :( how can you pre press 20 mugs if you have only one mug press :D
Re: frosted mugs
What you do is wrap the paper around the mug as normal. Put in your mug press at a temp of, say 70 degrees and leave for 5 minutes. Then increase temp to 155-160 degrees and press for a further 5 minutes. This works fine. Yes they take a long time, but any quicker will probably crack the mug. We have these frosted mugs as well as whisky glasses which have to be pressed this way.
Re: frosted mugs
I think I going to skip froset mugs then :) is it this same with frosted beer glass??
Re: frosted mugs
Pretty much the same with all glass products as glass is a very poor conductor of heat so it takes longer.
Re: frosted mugs
thanks martin! will stick to ceramic :)
btw... any good deals for mugs martin??? as I am not fancy to order new bumch of ebay so i would give yours a go as people give them thumbs up so many times...
thespringonion
Re: frosted mugs
Post by thespringonion »
one idea is to load your conventional oven with mugs at a set temp and press from there!
lovecut though... :?
Re: frosted mugs
thespringonion wrote: lovecut though... :?
ye ye i know but they got good price on them. :P
Kaz
Re: frosted mugs
Post by Kaz »
I was going to suggest pre-heating them in your oven, but I see Patrick beat me to it :lol:
The only problem I'd have with that personally is, my kitchen and my office are 2 storeys apart, so I'd be up and down the stairs more often than anything else :lol:
